Potato Cakes
Hello,
So after spending a fair amount of time away from this guy and working on other projects, I've circled back and am trying to finish this guy up. I've sorted the buzz and everything sounds like it's working, but I'm trying to incorporate a send 'n' blend circuit with the cavendish. I've picked the spots that seemed to make sense for extracting dry and wet signals, but I what I'm running into is the dry signal's polarity is reversed from the wet. I can get the blend circuit to work without the Cavendish just fine and vice versa, but since with the discrete mod replaces the dual IC op amp with a single op amp, I haven't been able to find a spot return the signal back to the Cavendish without cancellation of the wet/dry signal. What I think is going to end up happening is that I use the DOA for the input, use the NE5532 on the output, take a signal off of the OUT 2 pin and return it to the OUT connection of the second DOA on the Cavendish (minus the op amp, of course) so that it hits the transformers before being set free. I could also incorporate another transformer wired out of polarity (which I'll experiment with just to see), but then we start getting into silly town. If I have overlooked something on the schematic where I can get in and out more sensibly without cancellation of the two signals, I'd love to know
I know some here would just say leave one of those boards out, and I generally would, but this was one of my first projects and after much pain and agony that goes with being new at DIY audio and wanting to do all the cool tricks and mods at that same time, I'm just wanting to wrap this up as I am trying to finish all the other builds I have sitting around before I attempt to do any more projects. I'll do a fun post on GSSL help thread when this is all done.
Paul
Paul
