owel
This is based on a 1970s design of a line preamp using all discrete transistors. This is my first prototype, so forgive the messy looking board, the mismatched transistors, and the trimmer resistor hanging by wires.
I just used transistors that I have in my parts box, and used some TO-3 power transistors for that "Neve" vintage look... even though a TO-92 will work just fine. Also replaced some resistor and capacitor values to suit my taste.
The output trafo came from buttachunk and according to him it came from an MCI416 console. It sounds great.
I still need to do the mic preamp portion which will go in front of this unit... This will be powered by 48Volts. (Don't want to deal with separate voltages for phantom and board, so it's just one 48Volt) . In my testing, I powered it with 40Volts (that's as high as my bench PS can go).
It sounds sweet, effortless reproducing bass and low frequencies, and to my ears seems there is a slight scoop in the mid frequencies. It sounds nice in my opinion. And headroom... there is lots of headroom in this baby.
And some oscilloscope shots...
27Volts peak-to-peak @ 1Khz
27Vpp @ 10Khz
22Vpp @ 100Khz
And some square waves
33Vpp at 1Khz
33Vpp @ 10Khz
The rise time is alright, but the falling edge is kinda slow....
22Vpp @ 100Khz
Okay, that last shot there at 100Khz doesn't look anywhere near a square wave.
Are these peak-to-peak values enough, or too much?
Anyways, I plan on building a mic pre with input trafo and phantom power to go in front of this unit for a complete preamp stage.
27Vpp @ 10Khz
22Vpp @ 100Khz
33Vpp at 1Khz
33Vpp @ 10Khz
22Vpp @ 100Khz
