Hello all,
I have been working my way towards an 8-channel 1U green pre unit.
I’ve started work on the PSU requirements for the project, and have been initially working off the Green Pre design found here;
http://www.lorcan.me/projects/green-mic-preamp/
I have obtained a toroidal transformer, the data sheet for which is here;
http://docs-europe.electrocomponents.com/webdocs/0da0/0900766b80da0cc3.pdf
My questions are as follows;
[list type=decimal]
[*]I see that the PCB layout for this PSU has connections allowing for four channels of preamps. Will this design allow for 8 channels, with the addition of additional connectors?
[*]The transformer I have obtained is 230 input, 2x 15V output at 30VA. Is this sufficient to power 8 channels?
[*]According to the data sheet, I notice that each of the 15V secondary windings has its own 0V wire. The PSU power input connector has 3 connections, two for 15V and one for 0V. Am I correct in saying that I should connect the 0V wires of both secondary windings to the same 0V input on the PSU board?
[*]I will be adding a fuse for additional safety, inside a fuse holder. At which point in the circuit should this fuse come?
[*]What type of fuse is most suitable? Am I right in saying it should be a fast-blow type?
[/list]
Thanks in advance for any help. I rarely post, but scouring the pages for information pertaining to these questions has left me with more questions! And seeming as it’s a matter of mains voltage and potentially safety, I thought it best to ask.
Regards
Alex
