The Allied has no split/dual primary, so it's 110/120V only, the Hammond has 100/110/120/200/210/220/230/240 as primary voltage options. It's also rated VERY slightly higher in terms of VA, but if you're building a US-Only LA-2a, the Allied is the less-expensive option, of that there is NO doubt!
They're perfectly quiet, both mechanically and -in the completed unit- electrically. I also believe that they're manufactured by Hammond to the same standard as the 369JX, but made as a volume batch using a slightly shorter body, and with only 110V/120V primary windings,
they were the standard power transformer for the BLOO LA-2a's, and the Hammonds were supplied only for those kits going overseas, at extra charge IIRC. The quality is the same for both.
Keith
millzners said:My next cost reduction will be in sourcing Cinemag xfo's instead of Sowter -- that could save over $70 depending on what they quote me with shipping.
regularjohn said:millzners said:My next cost reduction will be in sourcing Cinemag xfo's instead of Sowter -- that could save over $70 depending on what they quote me with shipping.
Which cinemag's are you looking at?
Just curious because I've always used the sowter - and although they sound amazing - they are really pricey. And the way exchange rates are going they're not getting any cheaper!
Kingston said:I have tested the CM-9589 in LA2A build (the 50/50 steel/nickel version, not the high-nickel one). It's one of the finest 4:1 step down output transformers in the world. You simply cannot go wrong. The impedance difference between 4:1 and 5:1 in this circuit is completely negligible. Think of it as 3dB of "free gain" for the 4:1 version.
Hey, it'll even work brilliant as LA2A input! (wired reverse of course)
No modifications needed in circuit whatsoever. Just read Cinemag datasheets for correct 600 ohm termination and wiring.
I know some sites and documents recommend 15k:15k and 10k/10k line level input transformers for LA2A. I personally wouldn't do this. It completely defeats the purpose of LA2A as a line level amp, or as a medium gain mic preamp. It also makes it difficult to really exploit (read:slam) the compressor. Don't be a pussy and install at least 1:4 input.
bury the needle
millzners said:CMMI-8C 150, 600 : 10K which would give me the same ratio if wired for 600, but it's meant to be a mic input (probably doesn't make any difference).
The more intriguing option is the CMQEE-3440A 37.5,150,600 : 50K, which would give the same ratio and impedance as the Sowters and UTC models... That I think, besides the fact that I'm not sure how expensive it is, seems like the best option.
Kingston said:millzners said:CMMI-8C 150, 600 : 10K which would give me the same ratio if wired for 600, but it's meant to be a mic input (probably doesn't make any difference).
Be careful when substituting the input transformer with a mic input model. Keep in mind LA2A is line level unit first and foremost. Mic inputs generally won't take line level gracefully. Many will crap out (nasty clip) at standard mixdown levels and input pad is the last thing you want in LA2A.
The input should handle at least +10dBu gracefully. Notice +15dBu spec of the Sowters, it's there for a good reason. Check the transformer datasheets. None of the Cinemag mic input models are well suited for this task.
That said, CM-9589 will also work very well as LA2A input, even if it's not exactly marketed for that kind of tasks. I've tested it as input transformer, just not in this exact circuit, but very similar anyway. It has high (actually extreme) level handling capability, and flat frequency response. No distortion to mention.
millzners said:looking into a Drip T4B instead of the StudioElectronics.biz reissue b/c I'm trying to cut costs for this initial build understanding that at some point I can always upgrade to a reissue or a vintage T4B.
I'd prefer to have that gain knob up to around 5 or 6 most of the time to get those tubes working, but having never owned one of these things maybe that's wishful thinking...
regularjohn said:Nothing against David Kulka, he's a brilliant tech and knows his shit inside and out. But I agree with you, the prices at StudioElectronics are absolutely outrageous! I'd never buy from there unless it was the ONLY place open at midnight and I had crazy mad munchies, you know what I mean!
Find my posts in this thread about actual dB gain for various popular ratios, and think about that.
"getting those tubes working" has nothing to do with the position of the knob, the tubes don't care where the knob is, so long as the input voltage is sufficient to drive the output to at least unity. The importance of the position of the knob is mostly in the user's mind. When the knob is almost entirely off, there may be some issues with ability to fine tune levels, and you will begin to hear some HF roll-off.
sircletus said:Using that "logic," the Hammond could supply enough current for a single unit, but the Allied that many people are using couldn't, as it's rated 500V @ 40mA.
regularjohn said:I've used the Allied for four different LA2A's and all sound and work fantastic! And I've never had any issues with the power trafo even getting noticeably hot, as it would if it were being overworked.
