Biasrocks- If you are talking about R29...It is a 4.7k 2 watt mfr...
on a side note...I have no ground off of the input tranny- The Sower 1009 has a center tap on the Primary side, but no ground that connects the core(Will this be causing the audio signal problem?)
C7B= shows 353 VDC... I will re-measure again turret points later tonight
I also noticed in cayacosta's layout...he has the power transformer set up, as the the two black wires tied together(seperated to two different turret points, and then linked together, with one side going to the switch...(Wouldn't that cancel out that side of the Tranny?)--* I followed the 68 schematic and set up the top side to have the top of each winding to go in on the Blue and Black wires of the tranny..((How the 369jx is set up)) as 4 and 3...and then the wh.blu/wh blk as 2 and 1 on the negative side connected to the fuse
The only thing I question, is maybe the transformer primary is upside down then? I need to move the black to 4 where I have it at 3 right now...but the 68 schematic does not reference which tranny it is using... I would think this would not make a difference, but maybe it does?
