college101
Hey guys! Im back..My son was born, he is doing great, and I actually have some time to go down to the bench and get back to workin on the la-2a
Unit is passing Audio
After doing some research...First couple things I am going to check out( Pop in here with your feedback at anytime!)
First few things I am going to re-check
R38-220K or 22K res ?????
R4-does it really matter if it is linear or not?
C10-100uF/25v
C13-510pF /450V
C14- arco 465(shoud not be part of this problem)
C15- 470 pF/450V
I printed off the Voltage Chart from DJ's book- Im going to re-check all the voltages from the tubes
with respect to ground....SO basically set my black lead to the ground, and then test each point with the Red lead...((Right?))
In terms of having the back panel control's set correctly....they are supposed to be turned counter clockwise when looking at the inside back panel((Correct?)) y/n ?? ACTUALLY- just tell me from looking at the back of the unit,,,looking directly at the unit with the tubes facing me...which way should the controls be turned!! That would help...
Thanks Guys
C10-100uF/25v
C13-510pF /450V
C15- 470 pF/450V
Thanks Guys
