hyde maintenance
Active member
Can anyone shed some light for me on how to go about hooking up one of these racks?
Each unit has a single 9 pin molex connector housing an in and out connection as well as a key for the Kepexes. Each connection has a high, low and ground even though the Gain Brains and Kepexes are unbalanced.
When I hook up the Gain Brains according to the diagram on the back of the unit (using high, low, and ground) and using only the in and out, I am getting a bunch of crosstalk and interaction between units. This seems to be because the 'low' connections are common like ground (but not connected to ground).
I've tried lifting the low, switching low and high, switching low to ground and then ground to low...basically flailing around.
The one thing I've found is that if I lift the 'low' connection I get super weak and distorted signal, unless I connect these lifted leads, in which case the cross talk is gone but the comp seems to behave a little funky (plus this seems just plain wrong).
Sorry if this is elementary stuff but I'm a little baffled.
