matthias
hello!
I recently got some allison gain brain limiter modules and before I put them into
a rack enclosure I'd like to fix a small problem with the led meter and apply some mods.
1) nearly all modules have a problem with the led-bargraph:
the last or the last two leds are always illuminated,
even if there's no gain-reduction nor a signal at the input.
all other leds are working fine.
I think this is a very common problem with the gain brains.
There are only transistors and resistors in the meter circuit
Do you have an idea which part has gone bad?
2) do you have an idea if it's possible to add a pot for "attack control" ?
if yes, is there a resistor that is responsible for the "attack time" of the
limiter?
3) What would be your choice of transformers to add balanced
in- and output?
here's the schematic
pics of the module:
pic1
pic2
thanks for your help.
matthias
limiter?
in- and output?
pics of the module:
pic1
pic2
matthias
