Altec P518a / Coke Bottle mic strange issue
snoestudio
New member
hey guys,
I recently got an Altec 150a/21d capsule and P518a psu. I recapped the PSU and the mic is working with good sound and relatively low noise. However I'm running into something strange with the low frequency cut-off switch on the PSU.
The switch is a 3-position cut off at 20 (ie no cut off), 40 and 120hz. However, I noticed that I am getting considerably more low end at the 120hz position. I have checked the switch and the two caps that go with it to make the circuit, and I am totally confident that I have it wired exactly as the schematic; I've also checked the working of the switch and can see that it is doing what it's supposed to do (20hz position=no caps in circuit; 40hz=1 cap in circuit; 120hz= both caps in parallel).
There is definitely more low end at the 120hz position, and a hair more gain (maybe 1db more gain). The mic doesn't sound thin at the 20hz position, it's just that it seems bigger/bassier at the 120hz position.
I'm attaching the schematic here; can anyone with more experience than myself have a look at it? Is it possible that there is an error on the schematic??
thanks in advance for any help!
    96.1 KB
What output impedance is the transformer strapped for?  It could be that the secondary is not properly terminated by the mic pre and it is creating a resonant filter circuit causing a bump up at 120Hz.
thanks for the response. the Altec is strapped for 250 ohms output. I'm using a Studer transformer balanced mic pre with an input impedance of 1.2k. I never thought to try it with a different mic pre... I will do that and report back.
Switching caps on the transformer primary will be VERY load-sensitive.
Bypass that switch and bring your full-range signal in verbatim. You surely have better filters in your console and DAW.
In your post you said the 120Hz position has both caps in parallel. They should be in series as per the schematic you posted.
ok mjrippe you were spot on the money. I installed 250 ohm terminating resistors and the low cut filter now works exactly as it should. thanks everyone for your help!
And thank *you* for reporting back!  I'm sure it will help someone with the same problem in the future.
