ALTEC - Screw size ?
thomasdf
Paris, France
Hello
I am using a salvaged Altec 1606 rack enclosure to build a hinged front panel varimu compressor. The problem is I am located in Europe (France) and I cannot figure out what are the four locking screws dimensions. Easier to figure out a male screw than a female tap ...
Looks like it's around 3.9mm but that doesn't match with either a no6 or no8 screw...
Can anybody help me with this ?
I would love to find some thumbscrew for these.
Thanks a lot in advance
Thomas
edit : chatgpt tells me it may be a #7-32 UNC ?
    363.7 KB
It's rare to fined odd numbered imperial screws in the US. I've come across some #5, which is also what's specified by Switchcraft for XLR panels. They are special order pretty much everywhere.
Offhand I think those are #6 or #8, same screw on many other Altec pieces, and I've replaced them with other even numbered imperials....whichever they are!
Thanks Doug ! #8 seems to be 4.17mm, which def seems too big, as I can manage to screw in a M4 (4mm) a certain amount of turns only.
#6 seems to little (3.51mm) but I should def give it a try !
Another solution might be drilling & tapping for european screw ... but if I screw up (hmm..) the enclosure is shot
You probably already know this, but just in case - Imperial screws come in different pitches too. #6 comes in “fine,” (6-40, or 40 threads-per-inch), and “course,” (6-32, or 32 threads-per-inch).
Yep, though rarer to see the fine pitch versions. Usually!
oh dear. I misplaced those screws on a 1592 and remember thinking it was hard finding the correct match which makes me think a if they are a weird in between 7-32 might make sense? I think 6 felt like there was wiggle room
