Spencerleehorton
I've got some great transformers for U47's, work a treat in my Api-312 pre amps as well, only got 6 left.
Khron said:For example, the JFET + PNP combo that's normal in mics like the sE 2200A - that one has a 4:1 ratio transformer.
I was just wondering what's the worst thing that could happen if that got replaced with something like a Neutrik NTE10/3 (apart from the level reduction).
ln76d said:Khron said:For example, the JFET + PNP combo that's normal in mics like the sE 2200A - that one has a 4:1 ratio transformer.
Try, neutrik are so cheap that it's worth to try
Your output impedance will be around 30-40ohm so it's not bad for condenser.
Some condenser microphones have option for 200ohm and 50ohm outputs, changing connection of transformer windings, so it works
mhelin said:How about using two (cheap) transformers in the same output circuit, primaries in series, secondaries either in series or parallel (different ratio and output impedance)? Can you possible gain any mutual inductance by placing the transformers next to each other as close as possible (without actually taking the coils and bobbins and using some UI laminations to make the single transformer the proper way)?
Yeah, an answer I kind of expected. I guess even if the two transformers - as an example model I use "Eagle" LT44 / P631M transformer from Ebay / Velleman / www.electronelec.co.uk which uses small EI-19 core just a little bit larger than that of NTE10/3's and costs less than 2 pounds or 3 euros - had the cores/laminations welded together I think the magnetic flow wouldn't flow such way like in UI or C or other similar core transformer that it would give any mutual inductance. You could cut the middle sector of E-laminations and put two coils on the same core but the sectors left have only half of the width (about 3mm or so vs. 5mm) so it doesn't work well either. It's difficult to find such small UI laminations, or any other.gyraf said:..and no, you don't get any coupling by mounting them close..
