Am I reading this schematic correctly?
pucho812
third stone from the sun
This is part of a mic pre, it’s the input section.
Looking at how it is drawn am I correct in thinking that pins 1 and 3 are the primaries of the mic input transformer? And that pins 2 and 4 are the secondaries? They also appear to have a 1k resistor between primary and secondary connection…
    1.3 MB
That is a (common mode?) filter for some sort of noise reduction. Note it is marked as "L1" hence an inductor.
OOPS...I'm late to the party....thought I had posted reply half hour ago!
Bri "remember to click Post Reply"
These type CM inductors are in the Amek BC3 also , might have been Ruperts idea .
Not sure it's a -Rupert- idea, hopefully he didn't invent everything 🙃
I see this RF filter in most Studer mic in, broadcast specification request this I suppose, like the BC3.
I suppose back then, when operating radio program from field, control room in the truck with the transmiter antena on the roof of it, you better have a good HF filter ?
the ancients are always stealing our new ideas... ;)
It was explained , the choke is bi-fi wound with the windings connected in reverse so HF mush is neutralised ,
I dont see why a lower current off the shelf common mode inductor ,wired correctly wont do,
Were in an increasingly hostile environment as far as HF is concerned ,these measures make a lot of sense in new designs,
Having to tweak the neutralising networks with a scope across the stages of each channel in a big console PITA ,
I have the 24 bay BC3 , fully loaded you could cook eggs on it after prolonged power up ,
I might swap out alternate channels for blanking panels to see if it runs without fever .
I put fans in the armrests of mine connected to a temp dependant speed controller. Made a world of difference and almost silent!
