Hi Jens,
Very helpful response! Thanks!
Regarding the caps; Could you elaborate on which caps should have their values increased and by how much and also what value the bypass caps (I assume they are the "tantalum bead" or ceramic type?) should be and do you mean they should be on
every electrolytic?
Regarding the chips; I've been discussing with a friend of mine about possible replacements and he has a few ideas. I'll post anything I end up doing, along with results, here.
Regarding the VCA's; I don't think that there's anything
wrong with them per se, but channels 1-16 (the grey A10-A2 modules) either aren't connected (the ribbon cable slots are open) or aren't working. The VCA's on channels 17-24 (the blue A10 modules) all light up and appear to be connected. However, I've not familiarized myself with the automation functions due to lack of interest
. I've mainly read that the sound is improved by removing them and since it's a feature I'll never use, I thought I'd take them out or at least bypass them since I don't have the blanking plates to cover the holes that would be left with the cards out.
Regarding the power supply; That's good! I'll make an inventory list of the caps & order them. I've heard that increasing the value on these can also be beneficial, but I'm not sure which caps that would apply to.
Regarding the overall sound; I'm pleased with it, but it's a bit on the dark side and I usually find myself adding a bit of top with the EQ on lots of stuff. Also, I think the bottom end could use a little bit of tightening up. None of this is to the point that it's it's disturbing, but it is something I noticed right away. I'm very keen on the vintage character of the sound and the amount of space there is in the soundfield (i.e. it sounds deep & wide when I'm mixing), but I'd like to hear a bit more clarity & tightness. So I imagine the capacitor replacement/bypass you mentioned would provide this?
Thanks agin for your input!
Kind regards,
Frank
