ricothetroll
I'm currently working on an Amek Tac Bullet. After having done some cleaning, resoldering and removing the AFV section, I measured every channel's response using HOLM Impulse and Visual analyser software. This gives the frequency response, phase, THD/freq and impulse response.
I was surprised to see that, when most channels have a 0.00x % THD at 1kHz, some others show one as high as 0.x %, 100x higher. The most suprising thing with it is that this high THD sometimes disappears, when you check the measure again after having the channel moved from the motherboard...
I finally found out that the action causing this THD rise and fall is messing with the switches. Keeping the THD monitored in real time, pushing some switches back and forth sometimes lead to this raise in THD (quite hard to hit the "sweet spot" where the THD rises actually). This occurs not only on some particular switch but in any switch that's in the signal path, like PAD, MIC/LINE, PHASE, EQ IN/OUT... What's also surprising is that those are not noisy audiowise, that's why I didn't suspect them in the first place !
I guess there could be some stray resistance caused by dust or corrosion, that could overload th output drive capability of some active components.
Have you ever had this kind of issue ? Is there a known issue with that console's switches ? Would a shot of contact cleaning be enough or is it bette to replace those switches ? (that's a LOT of switches to replace...)
Thanx in advance for sharing your experience.
Best regards.
Eric
Best regards.
Eric
