jeremyaaron
Member
- Joined
- Nov 26, 2017
- Messages
- 8
Hi all,
I am troubleshooting an AMI U47 build that is complete according to the schematic.
My EF800 tube is completely cold when the PSU is powered up and I am trying to troubleshoot.
I tried the tube in another circuit and it heated up fine.
I thought the issue could be a cold solder joint, but the voltage going from anode to cathode on the tube seems to be close to normal, about 115V. The heater is really low though, about 1V from cathode to heater directly on the tube.
The mic capsule appears to be receiving the correct voltages and I can't find any point on the circuit that lacks continuity.
The PSU provided by AMI is putting out about
120V at Pin 3 B+,
60V at Pin 4,
2.2V at Pin 6 heater.
2.2V seems very low for a tube heater voltage. Would that cause the tube to be cold?
Is there a way to adjust heater voltage on the AMI PSU?
Is there anything else I am overlooking that could cause a cold tube and no sound coming from the mic? Broken cap, resistor, dirty components, etc?
120V at Pin 3 B+,
60V at Pin 4,
