I LOVE the sound of the 6SL7's.
What 6SL7s? They have a large unbypassed 2K or 5K resistor shoved up their butt, and that monster 470K resistor standing on their heads... 'bout any tube will work the "same" here.
You have gain of ~~25, loss of 10, gain of ~25, total gain near 60 at V1b plate. Inputs of 20mV to 500mV come out at 1.2V to 30V at V1b plate.
I prefer the one I posted... with the volume control LAST.
Probably because this forces gallopingly large signal at V1b plate no matter where you turn the volume pot. It is actually critical of player, axe, style, and taste: a stong player with hot axe and clean taste will find this to be "un-clean". Obviously it suits you.
You don't need ton-of-voltage-gain after this.
You do need a gain control somewhere or a hot humbucker with a heavy pick will smoke modern chip inputs.
You do need current gain, because the 6SL7 is working near 0.25mA, the silly chip-inputs are 2.8V at 10K or 0.28mA peak.
The plate resistance of 6SL7 at 0.25mA is 85K. You want your load to be higher. 10K is not higher than 85K. Poor match, voltage sags, distortion characteristics
change.
I think you want the official 1Meg pot into a cathode follower flowing 2mA-3mA. See
VT40 preamp, V3. As used here, it has 180K and 270K mix resistors, which happens to work out for those reverb and EQ paths. If you go 2-channel, use your B15-N mix resistors; for one channel you may omit resistors or try 150K to fade the supersonics. Then use the VT40 V3 plan, with 0.01u 1M 1K 47K 0.47u(!) 10K(*) 100K, exact as shown.
(*) For real low loads like modern studio gear, change 10K to 2K and for Bass consider making 0.47u a 1.0u if you can afford it. Should be Film cap and 400V.
The "12DW7" fragment is much like a 12AU7, 6C4, or 6S
N7. You could probably use both sections of one 6SL7 in parallel. This CF needs big current but noise and gain are non-issues, a good place to stuff any noisy tubes you get.
If you must have balanced output, use a 10K:10K transformer.
even if the resistors were exactly matched, isn't there still a possibility that there will be hum from the filament?
If your heater wiring is lazy and lop-sided, so low-level audio points "feel" more from one side than the other, then "CENTER tap" WILL hum. A pot lets you unbalance the electrical center similar to your wiring unbalance. If your wiring is fairly neat, the "best" setting will be so near the middle that "center" will be acceptable.
Note that you have different unbalance in each stage. And the sum of hum depends on the intervening knobs. If you really need a trim, you "need" to re-trim every time you change the Bass or Vol knobs.
explain the drawbacks in using the hum balance?
Cost 50 cents back then. Nowadays it is hard to find a suitable pot, could cost you $7.
There's a few reasons a hum-bal is worthwhile. A PHONO stage needs a much lower hum level than any gitar. We trim the whole hi-fi for low hum on Phono and hope to disregard hum in later stages. And later Ampegs used PCB construction with 6VAC on traces on the PCB... a technique which MUST hum. My VT-40 responds to its hum-pot, and is just barely better when off-center. This is actually a bad reason to use a hum pot: get the AC out of Flatland and up into twisted pair!!!! We know why Ampeg had to reduce hand labor with PCB, but you don't.
