Hi !
Seems like there's some deep SVT knowledge here
I'm currently repairing my Ampeg SVT-VR. The schematic is here :
http://www.bustedgear.com/images/schematics/Ampeg_SVT-VR.pdf
It had blown a 6550 output tube so I decided to go for a new sextet. I bought the EHX ones as they are the only ones I could find that are rated for 800V plate voltage, instead of 600V for most other 6550 out there.
Could be interresting to note that the blown tubes has its heater that is open. There are some tiny pieces of glass in the bulb so I guess the bulb is broken somewhere and so the heater burnt because of air (oxygen) got inside the tube.
So I first removed the tubes and checked that the preamp out is fine, and it is. Then I scoped the signal at the 6550 grids without them installed, and it's fine, I have a clean sine in phase on the 3 "push" tubes and with reversed phase on the 3 "pull" tubes.
Ripple on B+ is 5Vpp, scoped J11 and J12 after the OT.
So I installed the 6550 and biased them at 21-25mA per tube. A 4R/1200W dummy load is connected to the output. Tube bias has been set with TAD BiasMaster, that measures the bias by inserting a 1R resistor in series with the cathode and measuring the DC voltage across it to find the current.
Ripple the is about 15Vpp on B+, which seems pretty OK according to my simulations (Graetz bridge + 50uF reservoir).
When I put a 1kHz signal at the input I get the signal seen on the image linked below : 1kHz modulated by some kind of 100Hz signal. I guess that is the ripple playing...
https://drive.google.com/open?id=136-yKlwcxI9EEcLI9AgI9thDiIgTk7hc
One strange thing that I noticed is that the bias LED circuit doesn't seem to be working fine : LEDs should light separately when the bias of one side is between 3*21.6mA and 3*26mA according to the comparator circuit, but those always light both at the same time and for much bigger currents (like 40mA IIRC)
Another strange thing is that when I put any of the 6 tubes from the new setxet in my tube tester, there seems to be some kind of leak between G2 and the cathode and between G2 and G1, but that only happens when the tubes are fully heated : must wait at least 1 minute before the "leak" LED of the tester starts lighting. This happens for EVERY tubes of the sextet, and when testing them for Gm they seem to work correctly. The "leak" schematic is linked below. It's done by connecting the electrode to be tested to R1-R2, with every other electrodes shorted to ground. Heaters are fed by an isolated supply (trafo secondary). Current should start flowing in the transistor from a leak of 62M to the ground which is quite a small leak IMHO, so I don't think the tubes are dead (hope not actually...)
https://drive.google.com/open?id=1ekVKqMrb6bQfTRsH2I_JXUwvGeTJ-bQh
Any kind of help would be appreciated...
Thanx in advance !
Best regards.
Eric
