dawsonaudio
I'm having an issue with my MM1100.
Its been a few months since using the machine. I've had it on for the last week or so running tape every day for a little bit. I'm noticing a 60 cycle hum when tape is threaded on and the end of tape arm is engaged against the tape in the "ready to play/record" position. When I swing the end of tape arm to the right/off the tape, the hum goes away. Seems like the motors are causing the hum...I've checked around inside the machine and couldn't figure out the source.
Any ideas?
Nate
Any ideas?
Nate
