Monte McGuire
- Joined
- Jul 26, 2013
- Messages
- 384
80hinhiding said:I have veroboard with copper on one side. I guess it's time to at least consider PCB.
ps. Ever use LC passes on the audio input for RFI filtering?
You're welcome!
A sleazy trick, which can avoid complex PCBs, is to tape a single sided un-etched board to the back of your circuit board to make a fake "ground plane". You have to somehow meaningfully connect your ground to this add-on board, hopefully at a number of places so that your circuit has low impedance to the board. Maybe you could drill holes from many ground nodes through the Vero board to the un-etched ground board and use short jumpers to stitch it together?
Barring that, I've found that even placing a board over a grounded un-etched board will provide a plane that will tend to eat up a bunch of RF. I've done this with single sided SMD - I didn't have component leads sticking out that could short out the real circuit board, so I can keep the fake ground plane facing up, making it easy to stitch to the real PCB, but you get the idea. My bench is on the 2nd floor of a metro Boston building, only 5 miles from an antenna farm, but with a lot of copper planes in and near my circuits, I have zero problems with RF and hum, despite having no enclosure for the circuits I test.
PCBs are great, but it'll take you a while to learn the software and built a library of footprints that work. For now, that might be tough, but it's worth considering. I use Eagle along with PCB Library Expert to make footprints, since I mostly use SMD, and it works well now. Still, it took me literally a couple of years to get fully up to speed. But, once you get SMD down, it's beautiful to be able to use a stencil to print solder paste, place the parts, and then reflow the board and watch everything magically flow and align perfectly.
As for LC RF filters, I've experimented with this a bunch, and found that simple RC filters are safer and often more effective. The basic problem I've found is that ferrites or lossy inductors can 'eat up' RF without conducting it to ground, which is great, but these parts, when used as a series element, tend to add distortion. The parts that add less distortion tend to be the ones that have low 'real component of loss'. In other words, they're basically clean inductors. So, if you use lossy ferrites, then you risk distortion from signal currents - the loss that appears to be resistive at RF is actually from nonlinearities that can bite you in the audio band.
So, if you then decide to use clean ferrites or wound inductors, you find that you need external resistors to add loss - a clean LC circuit simply rings, and does not get rid of RF. You can actually get RF "gain" out of them if you're unlucky. So, you're adding R to the LC to get loss, and you're worrying about inductor linearity, and at the end of the day, a simple RC filter can do just as well as an RLC. RC filters are much cheaper than RLC, much more linear, they won't ring at unfortunate frequencies, and they're physically smaller. So, I've given up on ferrites and wound inductors for RFI filters, and haven't been unable to do whatever I needed to do without them.
