So this number can't simply tell you if tube is up to the task for, say, 20-25dB GR. It depends on output tube, SC and GR tube, it's all related and pretty complicated
As i understand it R100,101 (grid bias?) are changing gm of the tube. So amplification is changing by varying gm.
Am i right?
Class a/b and b are used in power amps where you want good efficiency. Preamps and compressors are normally functioning in class a, single ended or push pull (good cancellation of distortion and hum).
DaveP said:.................the negative DC output from the 6AL5 adjusts the grid voltages of the 6BC8 changing its gain instantaneously with the output voltage. It varies from 0V (maximum gain) to -10V (minimum gain). .....................The halves of the tubes have to be very well balanced to avoid "thumps" (low frequency noise) from this type of circuit.
all the best
Dave
eskimo said:Here's the Collins 26J schematic + description, really similar, so it might help someone.
http://eskimo.creotia.com/collinslimiter.jpg
gary o said:... I like all of us have searched and found so called EMI mods but all the ones I found so far are disproved ...
