Bo Deadly
Can I ask a potentially silly question. Why are you nulling? Is it not sufficient just to FFT the output signal?
The null test was just to test the test rig. But it didn't work so I'm wondering why.
Maybe now is the time to ask "how do I FFT the output signal?"
I don't think it makes any significant difference. What does make difference is how they are connected to "ground". Ground circulation currents must be thoroughly separated from sensitive nodes.
Analyze your lay-out. Consider every connection as a resistor.
I don't know where these green wires on the 1st pic go, but I think there are too many connections to the audio ground.Ok, thanks. I've attached a couple of pics of the grounding setup. I have 2 separate connections to chassis - 1 for the PSU, and 1 for the audio. They are on either side of the rear panel. With mains/transformer grounding I included a couple of ground connections from the PSU area of the PCB. On the audio side, there is one ground from the PCB as well as the XLR i/o.
Thanks.You need to twist each of the AC pairs together. Not super tight but just enough so that the two are touching and there's no gap in between...then measure again. I think you'll find your noise drops by quite a bit.
Ah, ok, thanks for that. Up to this point I've been grounding each point of the PCB where marked, instead of just one. I didn't want to run any risk of not grounding properly.Also, technically we (I) advocate that the chassis be connected to the power supply ground at the filter cap(s) and that's it. So one single fat wire between the chassis and the PCB. Right now you have at least 3 such connections just from looking at your pics.
I'm going to try and work this one out, after I do this basic testing on my gear.The analysis software is not responsible for not getting a good null test. The samples of each channel have to be aligned perfectly and my guess would be that they simply are not. I wouldn't break your back trying to figure that out. Null testing is very useful but it's a little more advanced than you need right now.
Thanks abbey and warpie, I'll sort this out and re-test.To me it looks like you've connected the pin1s to the XLR lug, to the chassis and to the audio ground on the PCB. Pin1 should be connected only to the XLR lug. Disconnect that 3-green-wire-lug from that bolt that is attached to the chassis and measure again.
