critterkllr
Eliani said:But as we speak I'm working on something far more important for the little Sorpion! Something to do with inductors!!
Keeping fingers crossed for a time machine!
bluezplaya said:Mmmmmmmmm.....! Inductor EQs! So how much would the 1512 boards be? And I'll bet they'll sound way better than the SSM2015s.
bluezplaya said:I finally got around to building four of the GAR 1731 opamps and tested the first one out on the S1000. So, it works, but at a very low signal level and the gain does not work. I was not aware, so rereading through the thread I learned that I will need to rewire or replace the gain pot. Can you tell me what I will need to do that?
I listened to some mp3s through the modded channel next to a stock channel and the EQ really thumps! Overall it does have a slightly more pronounced and beefier midrange.
jensenmann said:I don´t want to rain on your parade, Eliani. But simply throwing API into a circuit doesn´t make everything necessarily better. I once refurbished and modded a Scorpion for a friend. I left the bad and ugly SSM2015 in and modified the circuit around it to make it perform better. The result was that the owner sold his API preamps because they found no more use.
Your circuit suffers of mediocre CMRR. If that´s of no significance then go ahead. If it matters then the stock SSM performs better. In certain surroundings technical parameters do matter because they translate into percieved sonic quality. Not everything can be justified with "if it sounds better then..."
Just my 2ct
Just my 2ct
critterkllr said:jensenmann said:I don´t want to rain on your parade, Eliani. But simply throwing API into a circuit doesn´t make everything necessarily better. I once refurbished and modded a Scorpion for a friend. I left the bad and ugly SSM2015 in and modified the circuit around it to make it perform better. The result was that the owner sold his API preamps because they found no more use.
Just my 2ct
I'm curious about something; So, you would say that the absolute best sounding gear specifically relates to it having the highest CMRR?
critterkllr said:It's great that a previous customer enjoyed your modded preamps so much they decided to get rid of their API preamps. That is really what we're all after. Whatever sounds the best to the end user is the best.
As for the argument that the API line input circuit is going to sound worse that modding the stock circuit, I'm not sure how to go about that without getting into subjective territory. Perhaps you could elaborate on your mod and possibly how to improve on the API circuit? Have you tried the API circuit mod?
bluezplaya said:What exactly did you do to mod the circuit around the SSM2015?
jensenmann said:bluezplaya said:What exactly did you do to mod the circuit around the SSM2015?
There´s an input filter which I opened up a bit to get rid of HF phaseshift. Then I modified the supply around the chip. There´s some small ceramics across the rails next to the SSM. I replaced these with 100uF electrolytics + bypasscaps. Then I modified something in the network around the SSM, but since it´s many years ago I don´t remember exactly what that was. Of course I recapped everything (usually with larger value caps), added bypasscaps to all electrolytics and replaced all chips downstream. In the end it´s the sum of everything I did which lets the SSM perform better. And it does help to keep the EQ engaged even if not in use since the SSM doesn´t like to see much load at it´s output. The EQ circuit works as a buffer for the SSM this way.
jensenmann said:Rereading my first post let´s me think that it sounds a bit harsh. It´s not meant this way. I only wanted to add the CMRR thing for the record. No offence intended. And I´m totally with you about the beauty of DIY to tailor everything to fit one´s needs.
jensenmann said:That´s not so easy done in this scenario. Depending on how things are connected to your input it will represent different impedances to the source on + and - inputs. Transformers of course will handle this problem great. But that may not be an option here.
critterkllr said:What kind of input transformer would do the job? Is it a simple 600:600 that would do it?
