critterkllr said:I have this strange issue that started popping up. Occasionally channels will start crackling, then get really bad to the point where it overpowers everything. I've had it happen to 5 channels so far over the past couple months. Each time I had to swap out the gar2520 for a different one. Then, the opamp continues to crackle if used in different channels.
Is this something that could be related to the design of the preamp? Perhaps it happens when the console is being power on?
bluezplaya said:I just bought a multi-effects unit and I'm trying to patch it through my Scorpion. I've got 32 channels, 2 aux channels, and 8 subgroups. I'm wondering what the best way is to do this. I was thinking of using one or two of the subgroups as the master fader for the effects, and assigning those channels to the groups is a no brainer, but how would I get individual levels of effects for each track? Or should I go through aux channel? And if so, would that take away a headphone mix?
I have the Scorp manual, but it's so convoluted in some areas and I learn better from a 'do this, do that' scenario.
bluezplaya said:I just plugged it up through Aux 1 and all is well, but I'm wondering how I can patch individual headphone mixes for tracking.
Eliani said:critterkllr said:I have this strange issue that started popping up. Occasionally channels will start crackling, then get really bad to the point where it overpowers everything. I've had it happen to 5 channels so far over the past couple months. Each time I had to swap out the gar2520 for a different one. Then, the opamp continues to crackle if used in different channels.
Did you have any more issues with your opamps? Did you manage to fix your opamps?
Eliani said:I'm glad!, but sorry you have five casualties... But if I recall correctly your great at soldering more DOA's... ;D
