http://www.groupdiy.com/index.php?topic=5306.msg63842#msg63842
1:10 step up on the input, it's a sower 9045
And his output iron is a sowter push pull 9050.
Useable inputs are:
CMMI 10C
Sowter 9045
Useable outputs are:
Sowter 9050
Would any cinemags fit the output application well?
I wonder if UTC A-11 and A-25 would work. I know that they can be used on the BC-2B..
Push-Pull..
now I have to do some homework.
I would sincerely appreciate it if you gurus helped me with a few questions here, before I end up in a hole while building this.
Push pull.. this means that the PSU go's to the op iron CT? That's bizarre. Why?
Is the BA-2 originally a push pull circuit? Would I have to alter anything in my BA-2 to use a push pull OP xfrmr? It does not look like a push pull circuit when I look at the schemo, unless there is something coming from that switch at the bottom that I do not understand.
Schematic:
http://i98.photobucket.com/albums/l265/studiodave/ba2c13.gif
