The XLR connector is a bit loose. Not terribly so but there's a noticeable wiggle. What do I need to do to fix it? Tightening the Phillips head screw doesn't help.
If anything, isn't it good that it IS compliant, as opposed to having the pins fixed and stiff, and have them under tension / stress every time a connector is plugged in? As long as the ground-screw makes good contact with the housing...
