haima
guy - i think the echoplate design uses those a "link" - a bit like a single chain link with a thread+nut section on one side... don't know what they are called - page nine of jim's pdf shows them:
http://www.platereverb.com/manuals/Plate%20Construction.pdf
i've had pretty good luck with jim's clips on my 140 once i decided to use slightly less tension than he recommends, and slowly approaching the tension at each point evenly. i also made sure the plate was centered and i chose the hole in the plate corners that resulted in the clips being straight, not angled (there are two holes to choose from for each tension point on mine).
but jim's clips definitely don't seem "unbreakable" in my experience...
i think it's a good thing they do break in many ways - it stops you from stretching the plate - and you definitely don't want to do that - as they say, "the sound is in the iron".
there's a myth (?) that they had to stop production of the EMT140 once they ran out of that one particular batch of steel - perhaps that's not true... but it's a nice story
