Title says it all !!
Whoops said:I only have the documents (schematics and calibration) that are on this thread:
https://www.gearslutz.com/board/geekslutz-forum/1191251-tl-audio-m4-schematics.html
pucho812 said:let me look through my files, I think I have that.
I just added them to the tech library for you.Hi Guys, i own a TL Audio VTC wich needs some repairs- unfortunately i have not been able to locate any Scematics or a service Manual - just the normal one wich references scematics in the text but does not contain any.
So i would be really greatful if any of you could share them with me
Thank you so much Rob that will make troubleshooting so much easierI just added them to the tech library for you.
you can find it if you go to the home page and under the bulletin rider at the top you will find "tecnical documents"How do the rest of us find that "tech library" and the file in it?
does anyone have a Scematics for:
TL Audio EQ-1 Classic Series Dual Valve Equalizer Tube Preamp and Equalizer?
Thnx
https://groupdiy.com/threads/tl-audio.44989/page-3EQ-1 Schematics
Hi,I just added them to the tech library for you.
...or knows about this change ?
That would be awesome if you cold do that
I assume the hand marked revision field denotes the day rather than the revision
From what I've read on the 'net, TLAudio was a rather pequliar company .if they would print new circuit boards why not change the silkscreen…
So i assume that our Consoles have identical inputs and very similar EQ and fader PCB designs – also all based on 5532´s.
Can´t help but wonder what the sonic impact of this change is
no worriesIt'll probably take some time though.
it indeed appears to be soTLAudio was a rather pequliar company .
Our boards seem ineed to be quite similar – just checked the “tube PCB” – they are also marked copyright 2006.IIRC the other PCB's on mine had 2006 copyright markings.
thats a very good point and so far i´m happy with itOTOH, the sound of a console -or any other audio device for that matter- is much more than the op amp (/topology) used.
