rob_gould
Hi All,
I've always used Corel Draw for front panel design in the past but always free trials or buggy, unstable copies procured from the Internet.
I've recently come across Inkscape; a great vector graphics utility that is free and contains all the features which I need to make some decent looking panels and then export as .plt files which can then be imported directly into Front Panel Designer software.
But there's one hitch...
I cannot find a way to emulate the 'Contour to centre' feature in Corel Draw that is needed to make the 'inner lines' of any shape when engraving large single areas of panel to ensure that the CNC drill cuts out all the required material. The particular instruction I'm talking about is point 6 in here :
http://www.frontpanelexpress.com/fileadmin/pdf/tips_tricks/HPGL.pdf
Does anyone know how to emulate this feature in Inkscape? It seems this software is pretty much perfect for front panel design except for this (admittedly pretty critical!) flaw.
6.
To fill your object, all inner lines are created with the contour To Center feature. The
Offset of the lines should be spaced properly to avoid gaps. Gaps can cause burrs and
poor milling results. Using an end milling cutter, select half the tool width for the offset.
Engraving tools have a further reduced Offset, because they are tapered.
Optimal offset values:
Tool Offset
Engraving tool 0.2 mm 0.07 mm
Engraving tool 0.4 mm 0.15 mm
End milling cutter 0.6 mm 0.30 mm
End milling cutter 0.8 mm 0.40 mm
End milling cutter 1.0 mm 0.50 mm
End milling cutter 2.0 mm 1.00 mm
End milling cutter 2.4 mm 1.20 mm
End milling cutter 3.0 mm 1.50 mm
If your graphic contains more then one object and you want to fill between the two,
select both and choose Arrange and Combine. Now fill your combined object To Center
with the appropriate Offset as mentioned above. For graphics using multiple tools select
different color lines. Each color represents one milling tool.
