The Sugar Lion
Active member
- Joined
- Oct 7, 2016
- Messages
- 32
I was looking at the Fox Audio website and considering starting to work on the Mini-Mod that he has posted. I was hoping to just start with the very basic task of removing C9 & C10 to remove the 25K peak. My question is do I have to finish all the steps in the Mini-Mod for this to be safe or can I simply get rid of those two caps to start and continue using the mic?
Here is the step by step from his website for reference.
The FAR 460 Minimod
So what is the minimum you can do to make this mic. sound good? Turns out it's simple.
1. Remove C9 and C10 to remove the 25Khz peak resonance in the high end.
2. Change the caps in the signal path: Polystyrene input and 1uF polypropylene output (C8)
3. Change the tube to a 6072 or a very good 12AT7
4. Add a tiny EQ cap like that found in the ELA m251 design, between the Anode pin of the 1st stage tube and ground. ( I like 200pF myself but it depends on your capsule, sometimes 330pF is a better sound)
The FAR 460 Minimod
