deveng
Hoof wrote:
Yes, I think they are 1.5" spacing but......I never intended to put a 512 or 550 into my rack. This is DIY! Also, you don't see too many 500 racks for sell. They also use edge connectors which I don't like. So, I built everthing from the ground up and use high guality DIN receptacles as found on many high end consoles. I acutally looked into getting a used rack at the begining but choose to build it all. Lots of work but worth it.
Regards,
Jeff
API stuff is 1.5" wide, as I'm sure you know. Sounds like your rack is not compatible.
Regards,
Jeff
