mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
There is no trim pin on your board, that is your output. That resistor is some kind of load isolation and goes to your output trafo primary. (can you see the value of the cap next to it btw?)
I smoked one of those once on a clone (maybe clown is better?) but it had to do with a bad diode on the power rails or one I had put in backwards or something, not likely here since this was working before, but may want to check them anyway. I think diodes go open when they kick the bucket? Could be wrong. Anyway, the fact that the 47R saw enough current to fry it, could mean something shorted to ground. Check the board and if there is a short in the opamp you may be able to check for it on the pins. Sam Groner is the opamp expert, maybe he could lend a hand here.
Greg, I think it's more likely rectification for the meter since it's a dual opamp. Don't wanna ask to see the bottom of the board. Or did I just do that?
