3nity
Have you seen or used the new 512v?
Seems to be dual amp with variable output?
Weird...looks like a vp28 from capi.
Utilizing the same exact circuitry created for the original API 512c by Saul Walker, the API 512v changes things up by featuring a variable output level control that allows engineers to bypass the need for any external signal attenuation. This means no more third party devices are needed to get that beloved API sound when using your favorite DAW or other devices with sensitive input levels.
The API 512v follows suit with the design of the API 512c with the exception of the variable output. This means not only is the 512c’s complete circuitry intact in the 512v, but the module also employs the same proprietary transformer, API 2520 op-amp and high-quality components that API has always used when creating their popular pre amp.
