Api 553 eq with api-312
Pretty sure I could just patch in the 553 just before the output txf then connect its output to the 2503.
Need to fix up a couple of things, 4pdt switch needs attaching along with changing pots to 10k rather than 5k.
Wound my own 1H and 100mh inductors.
May change some caps for polystyrene?
Fingers crossed they still work!!
I had a little play with these again the other day and they work fine again, I think originally I must have mixed up the inductors I wound as there was something quite if with them.
As space is at a premium in the other api preamp I'm going to temporarily put them in a separate case and have it so I can patch them both into any of my 12 api preamps
