API Channel Strip MIC/LINE/INST selection issue
tadejm
Active member
Slovenia
Hello!
I have a flooded API The Channel Strip under repair.
The entire unit is cleaned and in principle works, but the problem is with the MIC/LINE/INST selection (API 512 C mic preamp).
(the same switch switches between the three - MIC/LINE/INST. The switch itself is ok, it works with HEF4017bt counter, ULN2803A and a lot of relays).
LINE and INST selection works ok, but does not switch to MIC selection... What would be the problem? Relays?
I was sure that it was faulty HEF4017, so I replaced it with a new one, but doesn't work.
Does anyone have a schematic of this unit?
