Just curious what is the general consensus when you compare DIY project vs Commercial Clone. I guess there are pros and cons to each one, ie. one relying on the builder and designer and the other being mass produced and cutting costs.
For example, if we were to compare Warm Audio Pultec and some of the DIY Pultec available online (maybe comparable value?), would it be safe to say, if you can build the unit, you are better off DIY as you can ensure better quality build and truer to the original design?
If there are affordable commercial clones out there, which do you think, you are better off buying the clone than DIY?
I built Mnats 1176 D a while ago because I could not afford the clones back then, but now its a more competitive space with more commercial manufacturers doing clones. I still love the build and the whole journey, but as I get older, I would like to avoid building projects I could buy commercially and use that time for other DIY projects or music.
Thank you.
Thank you.
