rna
- Joined
- Nov 20, 2015
- Messages
- 51
So I am thinking of making one of my projects available as a PCB with 121 SMD components already in place. It is a dual mono saturation device. It also has a switch to engage internal M/S processing. Builders will have to populate transformers, relays, opamps etc. Although I have made 2 19" rack cases for my prototypes I am struggling with getting a case worked out.
I have tried communicating with a UK case manufacturer however they were complaining that none of my files would open.
If anyone has a spare 5mins could you try and load my files. Hopefully I can find out where I went wrong.
Here is a step file
https://www.dropbox.com/s/qte39hjzeya60jd/82 moons VERSAMET.step?dl=0I have my Freecad file
https://www.dropbox.com/s/9xf4rc7uek8fgat/82 moons small v case.FCStd?dl=0And this is what it should look like
This case was taken from their CAD file and I was amazed it all lined up even with my Illustrator file I used and my 3d export from Kicad whilst building the prototypes. The 'comfort' handles need to be removed and as a CAD newbie I could not investigate the inside clearances.
Here is a photo of the unit in the rack. Its is such a simple design, I had considered the Don Audio cases but that is too pricey.
If anyone can shed some light on my files and maybe suggest a better export from Freecad.
cheers
matt
Here is a step file
cheers
matt
