Sniarf Eggbird
Member
Hi guys!
We had the luck of receiving a gift from my friend's brother the other day, .. a "blue meanie" arp2600 in a good state cosmetically!
after the first shock of joy and awesomeness we turned it on (110v from my bench supply - 220v from the socket here) and...
nada :-\ ... no sound at all ..
sliders ultra-hard to move too ...
to make the long story short, i opened the synth, it seems that they have replaced the original filter with a newer '76 4072 filter model and it has the 4027-1 oscillators.
BTW, i read that the "blue meanies" were the first 2600 Arp made.
Moving on i found a version of the Service Manual http://guitarfool.com/ARP2600.html which seems not to be full.
I read it and made my first tests ...
The manual suggests that first of all you should check the power-supply and you should get +15/-15volts ...
My +15 rail is ok but not my -15 ..... the minus rail gives out -3.2v .
In that situation, again the manual suggests to disconnect all molex pins that transfer power to each board one by one, in order to define which board is at fault.
I did that, but nothing really changed, i was disconnecting one board, checking, reconnecting it and moving to the next one.
After that didn't help, i disconnected all molex pins and measured my power supply without any load and voila, i got ..
+15.05 / -14.65
what i did after, was connecting only one board at a time and measure .. this is what i got ..
molex1 [preamp] = +15.03 / -4.33
molex2 [osc1] = +15.05 / -9.57
molex3 [osc2] = +15.01 / -6.85
molex4 [osc3] = +15.05 / -11.77
molex5 [filter] = +15.01 / -10->gradually drifting to 7.3 and lower
molex6 [env+amp] = +15.03 / -2.8
molex7 [s+h] = +15.05 / -3.0
molex8 [Lag] = +15.04 / -5.0
molex9 [noise] = +15.03 / -5.67
what do you think?
Does that mean that all of my boards have problem, or is it a power supply issue at first.
i hope for the latter ...
I would be also grateful if someone has a full version of the service manual that would like to share.
below there is a photo of the guts ..
Thanks for any input!
thomas
+15.05 / -14.65
what do you think?
thomas
