bsatriani said:Audiox, can you please indicate the output caps value?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/filcap.html
Вот кастомная версия этой печатной платы с восемью каналами от небалансного до балансного.
Надеюсь, Audiox, ты не против, что я настроил твою печатную плату!
https://www.dropbox.com/s/wjrwomyzt69f73i/300dpi8chbalancingcard.tif
[I think it should be 20K as the denominator instead of 10K for the un-balanced to balanced (channel 3/4)] -- See below and the response back in Post #34:I made an un-balanced to balanced make-up gain stage for a project today, using a bit of vero board and components out of the parts bin based on the schematics from Audiox. Thank you Audiox.
If useful to anyone, here are the original documents re-uploaded.
One thing I did notice was with regards to the gain calculations shown in the bal_card_block_diagram doc. I think it should be 20K as the denominator instead of 10K for the un-balanced to balanced (channel 3/4). Perhaps someone can confirm that please based on the schematic doc.
>> Chrispbass: THANKS!!! for the reuploading of these files. All of the earlier links are now dead and don't work -- ERROR 404!!!
>> Watch this space for further developments....."Please Stand By.....".....
[I may do a pcb layout at some point and share the gerbers] -- Should you happen to do your PCB-layout using either ALTIUM Designer, CADENCE/OrCAD or KiCAD.....PM me your PCB-layout design first and I will review it for you. Otherwise, PM me all of your GERBER and the N/C Drill data files and I will import and run them through a "GERBER & N/C Drill" data file analysis program that I have which will check your GERBER and N/C Drill data files for -- manufacturability -- issues >> BEFORE << you spend the money to have any PCBs made. Just sayin'.....Thank you Midnight….missed or glanced by those posts! Brains a bit flabby at the mo!
It’s a very useful circuit with minimal parts count, and although I didn’t have exacting values of components to hand, it’s working well with a few cascaded resistors etc.
I may do a pcb layout at some point and share the gerbers as It’s a very useful utility type circuit, unless you fancy doing it? Perhaps a stereo pair of each way may be the way to go.
Chris
