JamieOxford
Active member
- Joined
- May 7, 2017
- Messages
- 28
Hello,
I'm hoping to get some help with an Arp Explorer I'm restoring.
The envelope isn't fully closing due to a rogue voltage, but I'm struggling to find the source of the issue as the envelope circuit looks like one large feedback loop!
Turning up the release slider also increases the output volume when no keys are depressed - not sure if that is part of the original circuit design or a related issue (it could be stuck in constant release).
Attached is a PDF schematic. I've tested most components in circuit/some out of circuit and all seem to be working within a 10-20% value tolerance which seems typical of something from this era.
The circuit is working correctly at point F (the gate input to the envelope circuit). After this, all parts of the circuit are functioning but there's a residual -3 volts at the envelope output when no keys are depressed (at J / Z4-6), which is holding the VCA open.
Any suggestions on how to troubleshoot this?
