Melcor
Traced my AML-27 cards and drew up a schematic at higher resolution.
I have also laid out a reproduction PCB for these and will follow up with that eventually. My cards have some modifications so I used photos from Reverb and eBay listings plus the Barnett / Jeff Goodman trace above for value reference.
edit 2024: I have another AML-27 card which is a different PCB layout than my other cards (those ones are the same as the Barnett / Jeff Goodman trace). This card is definitely factory stock with no mods, including 1731, 400-17 output xformer, and 400-20 black rectangle input xformer. It has the most "vibe" out of all of the AML-27 cards I own! Very warm and punchy, way moreso than an API 312.
The circuit trace is the same, but the physical layout is different and it incorporates what appears to be a factory original 10K RV6 Clarostat gain pot and series resistor in place of what is otherwise the "R2" shunt arm resistor on both my original attached trace and the Barnett/Goodman trace (10K on my other cards, 7K5 on the Barnett/Goodman schematic)
The pot is wired as follows:
  • lug 3 is n/c,
  • lug 2 is a wire coming from the DOA Input- trace (AML-27 card pin 10),
  • lug 1 in series with a 1K2 resistor goes to the DOA Output pin trace (AML-27 card pin 12).
R3, which is otherwise the gain resistor, is 150R to ground/0v (AML-27 card pin 14)
R4 trim resistor on this card is 3K9. My other cards have 2K2 and the Barnett/Goodman trace notes this as 3K or 4K7.
C1 in the zobel network after the input xformer in all of my cards regardless of board revision is 1200p, rather than the 470p in the Barnett/Goodman schematic.
    320.9 KB
I'm working on racking some Melcor A24s for a friend so I've traced out the circuit to understand these modules better. I'm uploading the circuit I drew here.
Note these are the A24, not the ATP24. They are not the same.
  • Melcor A24.pdf
    51.3 KB
Hi guys - I feel very fortunate to have purchased, back in 1990, a pair of MAP Model 4003 / AM-27 Mic Preamp cards (w/ 1731A opamps), sale of which which included full documentation and also a fairly comprehensive MAP product catalog (which I can scan and post here, as I'm sure some would be interested).
More pics and scans to follow..
    3.1 MB
