Audio Note amp repair
Soeren_DK
Denmark
Hi there everybody.
I got this old amp that needs some attention.
The problem:
Without any source connected  to the amp  it's makes a lot of pops in the speakers. I suspect the PSU but I need some help. The top of caps looks a little bent.
Soren
    1,012.8 KB
If the pops are present on both channels, most likely the problem is as you already said in the power supply. The cap looks bent, but I don't believe that that's the cause of the pops. Do you have a scope?
