bjoneson
I'm in the process of bringing a mid 70s Auditronics Grandson (24 channel, 8 bus) console online.
I noticed it has an intriguing bus Topology.
The busses are fed via 9.1k resistors. Then hit a unity gain buffer (5534), which feeds the master fader, which in turn hits a line amp with 20-30dB of trimmable gain. The line amp is a 5534 in non-inverting configuration, with a pair of output transistors feeding a jensen 600:600 transformer. The monitor section is also fed from the output of this stage.
I'm used to seeing the virtual earth Topology, so this kind of caught me off guard. I'm curious as to the tradeoffs, and if there's any obvious opportunity for improvement. When the console was designed these would have been 301 opamps as opposed to the 5534s. They were incorporated in a later revision along with associated compensation network changes.
I'm comfortable with almost any level of modification all the way to etching and drilling PCBs if needs be. I have a number of 2520 and 1731 DOA clones laying around.
The board honestly performs astonishingly well as is. But I can't help but wonder if there's opportunity here.
