0dbfs
In for two.... Or so.. .
When you start the feeler that is.
Sounds awesome!
Jb
Sounds awesome!
Jb
Make sure you have a method to electrically connect ALL the body parts (including the mesh) together and to earth.Matador said:I did get a chance to shoot a coat of etching primer on all of the brass body parts:
And then a coat of gloss black on the same parts:
canidoit said:Is the quality of those cheap mic bodies, as good as the Neumann u87? Is the metal cheaper and thin or the-same? Does it have a cheap feel to it?
Would you say the quality of the body is comparable or even better than commercial mic bodies, such as Neumann, Bock, Flea, etc.Matador said:canidoit said:Is the quality of those cheap mic bodies, as good as the Neumann u87? Is the metal cheaper and thin or the-same? Does it have a cheap feel to it?
I've never held a real Neumann, so I can't comment. The Aurycle bodies however are solid brass and quite thick and heavy. They certainly don't feel cheap by any means.
In fact I would say the bodies are the highest quality parts of these mikes: the metal frames seem far cheaper and are just thin stamped metal straps with basic sheet metal screws. However they are same as pretty much all the other Chinese clones out there.
diyfanatic said:For European,
you can find at musicstore (germany) a Fame mic wich is the same as the aurycle body for something like 40€. or 70€ with shockmount and case.
Cheaper since shipping from US is pretty expensive.
cheers.
Jr.
