Avalon VT 737 sp
Here u go, should i open the PSU ? didnt saw any burned transistors on 5600-737
Orange 11,6
Black 34,6
White 188
Red 34,5
T1 182
T2 ? 6
R34 = 0
R43 41
Yes, open up to give it a visual check. You can pull the connector (3rd pic down) to measure the voltages.
Be careful.
I already pulled the moltex connecter, as i wrote down the messaurements of the connector
Didnt saw any burnmarks in the PSU, but i might be wrong, whats next to check?
    650.6 KB
    355.4 KB
    561 KB
    476.5 KB
    253.1 KB
Thanks for the photos.
From your measurements.
All is fine.
R34 shouldn’t get a measurement. 0v at R34 is correct.
Your voltages sound within tolerance.
Have you replaced tubes yet?
Have you replaced any of the 10uf and 100uf blue capacitors yet?
All is fine.
I already replaced tubes, no i didnt replaced any of them, should i?
are these the right type of capacitors? i think bout 25 of each of them should be enough, let me know if u think otherwise
https://www.mouser.de/ProductDetail/594-2222-036-90109
https://www.mouser.de/ProductDetail/594-MAL214258109E3
thank you for your kindness
Well let’s go back a minute before we do that.
What is the issue exactly?
Can we confirm the unit is passing signal properly?
So the problem is the following, I get only a very thin, very quit output, also its noisy neither the line or mic works properly
“Thin and low” as a description usually sends me looking for a single ended transformer first. Often as simple as a wire off on an XLR. Worth a check, anyway.
Can you get the meter to respond? For level and/or compression?
