K. Done for today. Be back tomorrow. Any ideas on how to test compressor.
Compressor calibration. All trim pots with the exception of gain reduction meter zero are internal.
In ye ad days, we ran a 1k sine at 0dBu into the line input with in and out pots at center detent. This should be line level 0dBu input identical 0dBu output with no compressor, eq, or high gain engaged. If not depending on how off it is, could be a trim pot or a bad component or worse faulty trace. If is a few tenths a db, adjust vr2 on main board until it’s 0dBu at measured output.
Adjust vr3 so that the meter reflects it.
Vr2 and 3 are on the motherboard. One is to the left of the vu meter while looking right at it, the other is behind the vu meter.
Pressed meter button to read gain reduction and adjust front trim pot to read 0 on the vu meter. It’s the trim pot you adjust from the front panel.
insert the compressor.
you should be measuring the output at all times.
There are 4 trim pots on the 7374 card that get adjusted. They are labeled below. Not to confuse them when trim pots on the main board as they share same part identifying numbers. It is a separate card.
Threshold all the way down
Attack and release at fastest it can be(far left)
Increase compression knob.
when the knob is at like 12 o clock l( between 5-6 on the silkscreen of the faceplate).
Adjust vr4 so that your output is -10dBu
Adjust vr3 (labeled -10vu) so that the meter should -10 on the vu in gain reduction mode.
From there move the compression knob to the 9 o’clock position.
Adjust vr1 on the same card so that you you see -3dBu at output.
Adjust vr2 so that the meter shows -3 in gain reduction mode.
Repeat -10 cal and -3 cal a few times as they are opto’s.
