TheseGoToEleven
Active member
- Joined
- Sep 4, 2020
- Messages
- 43
Sounds like the VU meter needs calibrating, because with the meter switch pushed in and the compressor button out, the UV meter should show zero. But at least you can say now that mic signal passes all the way through the first two tubes and reaches the output knob.The meter sits below zero. When I press it in it pins to the right. Definitely no signal on meter and when running into my console nothing. I stated before that the vu adjustment is pushed down alittle from the work they did on it. They replaced some pots and put regular pots. They put some black stuff to protect board. It’s just something I have to fix later on or might order 2 to do while I troubleshoot
Next, you might want to try the line input instead of mic input. Set gain and output to 12 o'clock, send in +4dBu and see what you get at T11, T12, and 65. This will see if the line input amp passes signal. If successful, check the line out XLR for signal and see what you get. Hopefully you will see +4dBu there as well.
