Matt Nolan
It is to calibrate the pad / attenuator switch.
ln76d said:What are the symptoms of "not so good". Noisier?
mics said:Yes introduced noise into the circuit is the problem.
Can you measure the response of the shelf EQ at the settings you use on this mike and post it here?elskardio said:I would like to open up the top end. Get a bit more definition in the high mid frequencies. I usually use a little shelf EQ while tracking to compensate.
ln76d said:If the circuit is exactly the same (i would verify that first, in your place), for quick some propositions.
C10 with 470pF-680pF Ceramic NP0/C0G
Gus said:Circuit has mixed bias
R6 source bias
R7 and R8 Grid 1 bias (look up cascode)
elskardio said:Hi Gus,
Could this method work for biasing the circuit? (this is a wild guess)
-Apply 1kHz sinewave to R1/C1 junction
-Connect oscilloscope to Q1 drain and select R6 for symmetrical clipping
-Then connect Oscilloscope to Tube Plate (Pin 5) and select R8 for symmetrical clipping
thanks
elskardio said:Hi In76d, why do you suggest to lower C10 (1000pf) ?
Hey, Thanks for sharing photos.Here are both a Sterling ST44 (left) and Advanced Audio CM28 (right) for comparison if useful to anyone…
