squarewave said:If the capacitor(s) lose capacity, ripple will increase. If it dips low enough, it will pass through the regulator and you can get hum. If the capacitor(s) are leaking, then the voltage may drop to the point where again the regulator will simply not regulate and the voltage will be low, you'll get hum and eventually horrible clipping. If one of the caps fails badly to the point where one rail is much lower than the other, a DC offset could actually cause an op amp to latch up one way or the other and maybe burn out something downstream. But that's theory to me personally. I've never seen caps fail like that. I recapped some stuff that was maybe 40 years old and the capacitors removed were still mostly fine.
moamps said:Additional problem is the high primary voltage which is over here 230V +/-10% what's about 250V sometimes, what causes overheating of the regulators.
This type of PS design flaw I see here in DIY also very often.
caps can be bad different ways.simonsez said:Hi all,
I'm curious what possible outcome/effect on the audio signal (IC based line amp) if one of the PSU capacitor filter (C1 or C2) get bad?
Simon
