I have 2 API clone units with the same power supply (whistle rock). One is a 2 channel, the other a 4 channel. The 2 channel, when racked, causes some crazy buzz on the unit right above it when powered on. (coming from the power transformer) The 4 channel does not exhibit this behavior if they are swapped. The buzz from the unit above can still be heard if i place the 2ch api 2 spaces away with another piece in between them. I have some MU metal strips, dont know if thats the correct solution for this, but was more interested in WHY this is happening with one and not the other. The only other difference i can spot is that I used a nylon standoff for the 2ch units power TX and just a long metal screw for the 4 channel. Could the TX be bad (even though its functioning electronically)? Thoughts?
