Would a first order low pass, using a single inductor to shunt the lows into ground, be a viable option? Forgive me if this is obvious, the conversation is quite a bit above my head already.
This is Butterworth, an excellent filter when you have no spectific goal.
Sure, I managed to beat a world record by including 3 typos in one sentence... Sorry about this.earthsled said:I'm thinking there might be a frequency variable missing from Abbey's capacitance equation. Perhaps it should be Cc=1/(2pi•Z•F) ? This gives me a capacitance value that is 1.125 uF (which is double compared to the other results).
What do you mean "impossibly large"? A typical mic xfmr has a primary inductance of about 5H. Look at the size of Beyer or Neurik xfmrs.earthsled said:The Butterworth filter requires a smaller capacitance and a larger inductance compared to the Shure schematic. Of course, 4.5H makes for an impossibly large component (as PRR suggested).
Yes.If I were to begin with the Shure values and gradually increase the inductance while decreasing the capacitance, would the result be a gradually flatter pass band (up to the point of the maximally-flat Butterworth)?
-20dBu (which is a very hot level for a mic)=> 77mV=> 30uW into 200 ohmsAlso -- for a microphone-level filter, would a 75mW transformer (used as an inductor) be sufficient, or would the 200mW model be a better choice? I ask because Mouser has some shielded models with the 75mW rating.
There is still an enormous risk of reverse voltage, if the phantom voltage is turned off, and you connect a 48V-powered signal to the input. I would never trust tantalum caps in this position.One more thing -- if the filter were to be placed after a phantom power circuit that offered some protection from DC, would tantalum capacitors be okay, or would there still be some risk of reverse voltages?
The shift in turnover frequency could be explained by a transformer with extremely low inductance, which wouldn't be correct for any quality audio performance, but the asymptotic response at -25dB below is not normal; probably noise. I think someting's wrong in your measurement set-up.earthsled said:I imagine it's the inductance of the input transformer in parallel with the filter that causes this shift -- is this correct?
That would make the alignment more exact, but it's not so important.earthsled said:Thanks for your reply.
Attached is a schematic of my testing rig. The components are mounted on a solderless breadboard, connected with twisted pairs and shielded cable where possible. The value of L1 ranges between 3H and 7H, but this doesn't seem to make a drastic difference to the frequency response.
Do I need to adjust L1 so that it equals 4.5H when in parallel with XFMR1?
Are you really running the test at -20dBu?
earthsled said:My main concerns are that neither of the plots appear to be "maximally flat" like the textbook examples Butterworth filters and the cutoff frequency of the "transformer" plot seems to be much higher than the intended 100Hz. The slightly underdamped response of the transformerless circuit is quite normal. With these values, the optimal load is about 3k. The actual load is much higher, so the circuit tends to be resonant.
As to the circuit with transformer, I continue to think that the deviation is due to the fact that its actual inductance varies with the signal level.As it is, your test setup is perfectly capable of producing reasonably accurate measurements.Perhaps my equipment is just not capable of accurate results?
As I mentioned earlier, it may explain why the response doesn't go down to minus infinity at VLF, but certainly not why the turnover frequency is skewed.earthsled said:Earlier, you mentioned noise might be the culprit so I put on my headphones and listened closely to the HPF circuit. I heard low-level hum when the HPF was in the audio path. Moving the circuit around, it sounded like the coil was acting like a guitar pickup -- transducing lots of stray magnetic fields from around my desktop. Would induced hum cause this irregular frequency response?
Do you have the possibility to visualise the wave form at the xfmr's output?
There's several free apps that do that. I recommend Visual Analyser.
earthsled said:Do you have the possibility to visualise the wave form at the xfmr's output?
Yes. Well, sort of... I hooked up my test circuit to an oscilloscope and used a sine wave generator for the input. I increased the level of the generator to the maximum output (about 0.6V p-p on the scope). With the filter, I can see the amplitude decreasing when the frequency is lowered, but I'm not seeing any obvious clipping or flattening of the waveform.
Maybe this is not the best setup for identifying the issue?
Since you have an o'scope, you don't need much more. I suggest you use the best audio analyser available: your ears. If you listen to the signal, you can tell if there is hum/buzz/hiss or not.There's several free apps that do that. I recommend Visual Analyser.Waterfall is good for analyzing resonances and transients. I was just suggesting using your PC (well...Mac) as an o'scope.Visual Analyser looks nice. Is it the waterfall-type view that would be helpful here? Unfortunately, I'm on a Mac, so the software choices are more limited. The app I'm using for frequency response graphs is capable of waterfall plots, but not in the demo mode.
That's probably because the inductor is not shielded. You can make a shield out of mild steel (cheap) or Mumetal (expensive), or you can use two inductors of half-value arranged in a humbucking configuration - that's probably the most efficient solution.earthsled said:Okay. Thanks for clearing that up!
Using an SM57 and the HPF into a mixer and headphones... I do notice an obvious increase in LF noise / hum when I switch the filter on. This noise / hum increases when the circuit is brought near almost anything electronic. The level of noise is such that I question if the circuit is even practical for use in recording.
Maybe I should explore a HPF that doesn't use an inductor?
